Revit UI Improvement - Export
I don’t see how to reload geometry from export window. Would it make sense to add button to reload geometry after change to revit model for quick re-export? Currently, looks like user would have to go make to step 6 in UI for geometry to reload.
Hi @victorbrac! This should be doable but I need to talk to @ksobon to ensure it doesn’t break the workflows.
Also to understand your workflow better, what is the scenario where you still need to make changes to the Revit geometry after moving from step 6?
Just thought it’d help with rapid testing. Many times I won’t see smaller issues until exporting to Rhino. Then I’ll make corrections in Revit and want to quickly re-export to see if issue was fixed.
