AirBoundary error: non-interzone surfaces
I’ve a large model where I’ve drawn many guide surfaces for AirBoundary. And here’s the error message from the energy run. Can I ask if there is a way to find out which 2 guide surfaces are non-interzone? Any PO command or debugging process you would recommend? Thanks.
** Severe ** SetupEnclosuresAndAirBoundaries: 2 surfaces use Construction:AirBoundary in non-interzone surfaces.
Found the solution: I filtered the internal floor of the PO model, and compared with the guide surfaces.
Hi @xavierzhou - Thank you for creating the topic, and also posting the solution! I appreciate it!
This is an error that the validation routine should catch for you and show you the problematic faces. Did the model pass the validation?
I didn’t add AirBoundary in the pollination model, because there’s no easy way to change AirBoundary once they are added to the PO rooms, I asked this question in another post.
