Color by face not working
After I did the installation of Rhino pollination version 0.131.1, I am not able to visualize anything on rhino display using color face by property tab.
Hi @asisnath! Thanks.
@mingbo, I can recreate the issue for FaceType and Construction but the rest are working for me. @asisnath, is this also the case for you?
Here is Energy - R-Value
Hi @asisnath and @mostapha, thanks. I found a bug in the case of “Construction”, but the rest items work fine on my side. Could you confirm that? If others don’t work, could you also please share a sample model for me to debug?
Hi @mingbo @mostapha I am having issue with all parameter, I am sharing the file in your inbox
Thanks @asisnath, I just fixed this issue and a new version will be ready in an hour.
