Preparando la instalación...
Instalando componente Python 3.7.9
Extracting "3.7.9python.7z"
Done
Instalando componente Pollination Handlers
Extracting "1.0.0content.7z"
Extracting "1.0.0python_packages.7z"
Looking in links: d:\Program Files\pollination/temp/python_packages
Processing d:\program files\pollination\temp\python_packages\ladybug_rhino-1.29.10-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\pollination_handlers-0.7.0-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\ladybug_core-0.39.8-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\lbt_dragonfly-0.7.357-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\click-7.1.2-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\ladybug_geometry-1.23.9-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\lbt_honeybee-0.4.207-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\dragonfly_uwg-0.5.61-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\dragonfly_energy-1.12.132-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_radiance-1.43.9-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\lbt_ladybug-0.25.78-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_energy-1.76.13-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_energy_standards-2.1.4-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\uwg-5.8.4-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\dragonfly_core-1.29.26-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_standards-2.0.4-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_radiance_folder-2.5.4-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_core-1.45.6-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_radiance_command-1.11.5-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\ladybug_comfort-0.12.16-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\dragonfly_schema-1.6.47-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\ladybug_geometry_polyskel-1.3.29-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\honeybee_schema-1.44.1-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\pydantic_openapi_helper-0.2.7-py2.py3-none-any.whl
Processing d:\program files\pollination\temp\python_packages\pydantic-1.8.2-cp37-cp37m-win_amd64.whl
Processing d:\program files\pollination\temp\python_packages\typing_extensions-3.10.0.0-py3-none-any.whl
Installing collected packages: click, ladybug-geometry, ladybug-core, ladybug-rhino, honeybee-standards, honeybee-radiance-folder, ladybug-geometry-polyskel, typing-extensions, pydantic, pydantic-openapi-helper, honeybee-schema, honeybee-core, honeybee-radiance-command, honeybee-radiance, ladybug-comfort, lbt-ladybug, honeybee-energy, honeybee-energy-standards, lbt-honeybee, uwg, dragonfly-schema, dragonfly-core, dragonfly-uwg, dragonfly-energy, lbt-dragonfly, pollination-handlers
Successfully installed click-7.1.2 dragonfly-core-1.29.26 dragonfly-energy-1.12.132 dragonfly-schema-1.6.47 dragonfly-uwg-0.5.61 honeybee-core-1.45.6 honeybee-energy-1.76.13 honeybee-energy-standards-2.1.4 honeybee-radiance-1.43.9 honeybee-radiance-command-1.11.5 honeybee-radiance-folder-2.5.4 honeybee-schema-1.44.1 honeybee-standards-2.0.4 ladybug-comfort-0.12.16 ladybug-core-0.39.8 ladybug-geometry-1.23.9 ladybug-geometry-polyskel-1.3.29 ladybug-rhino-1.29.10 lbt-dragonfly-0.7.357 lbt-honeybee-0.4.207 lbt-ladybug-0.25.78 pollination-handlers-0.7.0 pydantic-1.8.2 pydantic-openapi-helper-0.2.7 typing-extensions-3.10.0.0 uwg-5.8.4
Done
Instalando componente Pollination for Grasshopper
Extracting "0.1.0plugin.7z"
Setting Rhino IronPython search path ...
Congratulations! Setting the search path in the following file was successful:
C:\Users\Mauro\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\settings\settings-Scheme__Default.xml
Done
Instalando componente Ladybug Tools
Extracting "0.1.0content.7z"
Extracting "0.1.0talib.7z"
Done
Instalando componente Pollination for Rhino
Done
IFW Version: 4.1.1, built with Qt 5.12.7.
Build date: May 25 2021
Installer Framework SHA1: 45e77c3a1eb790d89f2ded5b7fbe556ed4b5271c
[0] Arguments: D:\Program Files\pollination\temp\installer.exe, --script, D:\Program Files\pollination/temp/install.qs, --verbose
[6] Operations sanity check succeeded.
[6] Language: es-ES
[566] *** Ladybug Tools Silent Installer ***
[566] Installing on win
[566] Loaded control script "D:\\Program Files\\pollination/temp/install.qs"
[566] Using control script: "D:\\Program Files\\pollination/temp/install.qs"
[591] Preparando la descarga de la información de metadatos...
[826] Activated successfully!
Note: you can deactivate the key by uninstalling the product.
[867] button AcceptLicenseCheckBox : QCheckBox(0x6c7c520, "AcceptLicenseCheckBox")
[867] button AcceptLicenseCheckBox checked : true
[871] Installation space required: "609.31 MB" Temporary space required: "256.00 MB" Local repository size: "0.00 bytes"
[897] Tmp and install directories are on the same volume. Volume mount point: "C:\\" Free space available: "75.95 GB"
[931] backup operation: Mkdir
[931] - arguments: C:/Users/Mauro/ladybug_tools
[932] Done
[932] perform operation: Mkdir
[932] - arguments: C:/Users/Mauro/ladybug_tools
[932] Done
[932] Preparando la instalación...
[932] Install size: 11 components
[948] Instalando componente InstallCheck
[948] backup CheckIfExpired operation: Extract
[948] - arguments: installer://CheckIfExpired/0.0.0talib.7z, C:\Users\Mauro\ladybug_tools
[948] Done
[948] perform CheckIfExpired operation: Extract
[1288] Done
[1289] Instalando componente Python 3.7.9
[1289] backup python operation: Extract
[1289] - arguments: installer://python/3.7.9content.7z, C:\Users\Mauro\ladybug_tools
[1289] Done
[1289] perform python operation: Extract
[1290] - arguments: installer://python/3.7.9content.7z, C:\Users\Mauro\ladybug_tools
[1293] Done
[1293] backup python operation: Extract
[1293] - arguments: installer://python/3.7.9python.7z, C:\Users\Mauro\ladybug_tools
[1293] Done
[1293] perform python operation: Extract
[5061] Done
[5062] backup python operation: License
[5062] - arguments:
[5062] Done
[5062] perform python operation: License
[5062] - arguments:
[5063] Done
[5064] Instalando componente OpenStudio 3.2.0
[5064] backup openstudio operation: Extract
[5064] - arguments: installer://openstudio/3.2.0content.7z, C:\Users\Mauro\ladybug_tools
[5064] Done
[5064] perform openstudio operation: Extract
[5572] Done
[5572] backup openstudio operation: License
[5572] - arguments:
[5572] Done
[5572] perform openstudio operation: License
[5572] - arguments:
[5574] Done
[5577] Instalando componente Radiance 5.3 (2021-03-28)
[5577] backup radiance operation: Extract
[5577] - arguments: installer://radiance/5.3radiance.7z, C:\Users\Mauro\ladybug_tools
[5577] Done
[5577] perform radiance operation: Extract
[6739] Done
[6740] backup radiance operation: License
[6740] - arguments:
[6740] Done
[6740] perform radiance operation: License
[6740] - arguments:
[6741] Done
[6742] Instalando componente OpenStudio Report Measures
[6742] backup measures operation: Extract
[6742] - arguments: installer://measures/1.1measures.7z, C:\Users\Mauro\ladybug_tools/resources
[6742] Done
[6742] perform measures operation: Extract
[6961] Done
[6962] Instalando componente Honeybee OpenStudio Gem
[6962] backup openstudiomeasure operation: Extract
[6962] - arguments: installer://openstudiomeasure/3.8.2honeybee_openstudio_gem.7z, C:\Users\Mauro\ladybug_tools/resources/measures
[6962] Done
[6962] perform openstudiomeasure operation: Extract
[7201] Done
[7201] backup openstudiomeasure operation: License
[7201] - arguments:
[7201] Done
[7201] perform openstudiomeasure operation: License
[7201] - arguments:
[7202] Done
[7203] Instalando componente Honeybee Standards
[7203] backup standards operation: Extract
[7203] - arguments: installer://standards/1.1standards.7z, C:\Users\Mauro\ladybug_tools/resources
[7203] Done
[7203] perform standards operation: Extract
[7292] Done
[7292] backup standards operation: License
[7292] - arguments:
[7292] Done
[7292] perform standards operation: License
[7292] - arguments:
[7294] Done
[7295] Instalando componente EPW Weather Files
[7295] backup weather operation: Extract
[7295] - arguments: installer://weather/1.1weather.7z, C:\Users\Mauro\ladybug_tools/resources
[7295] Done
[7295] perform weather operation: Extract
[8098] Done
[8099] Instalando componente Ladybug tools core libraries
[8099] backup honeybeecli operation: Extract
[8099] - arguments: installer://honeybeecli/1.0.0content.7z, C:\Users\Mauro\ladybug_tools/temp
[8099] Done
[8099] perform honeybeecli operation: Extract
[8103] Done
[8103] backup honeybeecli operation: Extract
[8103] - arguments: installer://honeybeecli/1.0.0honeybeepackages.7z, C:\Users\Mauro\ladybug_tools/temp
[8103] Done
[8103] perform honeybeecli operation: Extract
[8293] Done
[8293] backup honeybeecli operation: Execute
[8294] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, pip, install, -r, C:\Users\Mauro\ladybug_tools/temp/requirements.txt, --no-index, --find-links, C:\Users\Mauro\ladybug_tools/temp/honeybeepackages
[8294] Done
[8294] perform honeybeecli operation: Execute
[8295] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, pip, install, -r, C:\Users\Mauro\ladybug_tools/temp/requirements.txt, --no-index, --find-links, C:\Users\Mauro\ladybug_tools/temp/honeybeepackages
[8319] C:\\Users\\Mauro\\ladybug_tools\\python\\python.exe" started, arguments: "-m pip install -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt --no-index --find-links C:\\Users\\Mauro\\ladybug_tools/temp/honeybeepackages
[10463] Looking in links: c:\\Users\\Mauro\\ladybug_tools/temp/honeybeepackages\r\nRequirement already satisfied: attrs==21.2.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 1)) (21.2.0)\r\nRequirement already satisfied: click==7.1.2 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 2)) (7.1.2)\r\nRequirement already satisfied: click-plugins==1.1.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 3)) (1.1.1)\r\nRequirement already satisfied: docutils==0.17.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 4)) (0.17.1)\r\nRequirement already satisfied: dragonfly-core==1.29.17 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 5)) (1.29.17)\r\nRequirement already satisfied: dragonfly-energy==1.12.114 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 6)) (1.12.114)\r\nRequirement already satisfied: dragonfly-schema==1.6.45 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 7)) (1.6.45)\r\nRequirement already satisfied: dragonfly-uwg==0.5.51 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 8)) (0.5.51)\r\nRequirement already satisfied: honeybee-core==1.44.21 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 9)) (1.44.21)\r\nRequirement already satisfied: honeybee-energy==1.76.2 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 10)) (1.76.2)\r\nRequirement already satisfied: honeybee-energy-standards==2.1.4 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 11)) (2.1.4)\r\nRequirement already satisfied: honeybee-radiance==1.42.3 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 12)) (1.42.3)\r\nRequirement already satisfied: honeybee-radiance-command==1.11.4 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 13)) (1.11.4)\r\nRequirement already satisfied: honeybee-radiance-folder==2.5.4 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 14)) (2.5.4)\r\nRequirement already satisfied: honeybee-schema==1.43.10 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 15)) (1.43.10)\r\nRequirement already satisfied: honeybee-standards==2.0.2 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 16)) (2.0.2)\r\nRequirement already satisfied: importlib-metadata==4.5.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 17)) (4.5.0)\r\nRequirement already satisfied: jsonschema==3.2.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 18)) (3.2.0)\r\nRequirement already satisfied: ladybug-comfort==0.12.12 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 19)) (0.12.12)\r\nRequirement already satisfied: ladybug-core==0.39.4 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 20)) (0.39.4)\r\nRequirement already satisfied: ladybug-geometry==1.23.7 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 21)) (1.23.7)\r\nRequirement already satisfied: ladybug-geometry-polyskel==1.3.27 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 22)) (1.3.27)\r\nRequirement already satisfied: ladybug-rhino==1.29.9 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 23)) (1.29.9)\r\nRequirement already satisfied: lbt-dragonfly==0.7.306 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 24)) (0.7.306)\r\n
[10473] Requirement already satisfied: lbt-honeybee==0.4.171 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 25)) (0.4.171)\r\nRequirement already satisfied: lbt-ladybug==0.25.74 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 26)) (0.25.74)\r\nRequirement already satisfied: lbt-recipes==0.13.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 27)) (0.13.1)\r\n
[10483] Requirement already satisfied: lockfile==0.12.2 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 28)) (0.12.2)\r\nRequirement already satisfied: luigi==3.0.3 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 29)) (3.0.3)\r\nRequirement already satisfied: pollination-handlers==0.7.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 30)) (0.7.0)\r\nRequirement already satisfied: pydantic==1.8.2 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 31)) (1.8.2)\r\n
[10494] Requirement already satisfied: pydantic-openapi-helper==0.2.7 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 32)) (0.2.7)\r\nRequirement already satisfied: pyrsistent==0.17.3 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 33)) (0.17.3)\r\nRequirement already satisfied: python-daemon==2.3.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 34)) (2.3.0)\r\n
[10504] Requirement already satisfied: python-dateutil==2.8.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 35)) (2.8.1)\r\nRequirement already satisfied: PyYAML==5.4.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 36)) (5.4.1)\r\nRequirement already satisfied: queenbee==1.26.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 37)) (1.26.1)\r\nRequirement already satisfied: queenbee-local==0.3.15 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 38)) (0.3.15)\r\n
[10514] Requirement already satisfied: six==1.16.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 39)) (1.16.0)\r\nRequirement already satisfied: tenacity==6.3.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 40)) (6.3.1)\r\nRequirement already satisfied: tornado==6.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 41)) (6.1)\r\n
[10524] Requirement already satisfied: typing-extensions==3.10.0.0 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 42)) (3.10.0.0)\r\nRequirement already satisfied: uwg==5.8.3 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 43)) (5.8.3)\r\nRequirement already satisfied: zipp==3.4.1 in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from -r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 44)) (3.4.1)\r\n
[10535] Requirement already satisfied: setuptools in c:\\users\\mauro\\ladybug_tools\\python\\lib\\site-packages (from jsonschema==3.2.0->-r C:\\Users\\Mauro\\ladybug_tools/temp/requirements.txt (line 18)) (47.1.0)\r\n
[10595] Done
[10595] backup honeybeecli operation: License
[10595] - arguments:
[10595] Done
[10595] perform honeybeecli operation: License
[10597] Done
[10600] Instalando componente Grasshopper Plugin (Rhino 6 or 7)
[10600] backup grasshopper operation: Extract
[10600] - arguments: installer://grasshopper/0.1.0-1grasshopper.7z, C:\Users\Mauro\ladybug_tools
[10600] Done
[10600] perform grasshopper operation: Extract
[11767] Done
[11767] backup grasshopper operation: Execute
[11767] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug, set-config, ladybug-tools-folder, C:\Users\Mauro\ladybug_tools
[11767] Done
[11767] perform grasshopper operation: Execute
[11768] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug, set-config, ladybug-tools-folder, C:\Users\Mauro\ladybug_tools
[11773] C:\\Users\\Mauro\\ladybug_tools\\python\\python.exe" started, arguments: "-m ladybug set-config ladybug-tools-folder C:\\Users\\Mauro\\ladybug_tools
[11994] ladybug-tools-folder successfully set to: C:\\Users\\Mauro\\ladybug_tools.\r\n
[11995] Done
[11995] backup grasshopper operation: Execute
[11995] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, set-python-search, --python-package-dir, C:\Users\Mauro\ladybug_tools/python/Lib/site-packages
[11995] Done
[11995] perform grasshopper operation: Execute
[11996] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, set-python-search, --python-package-dir, C:\Users\Mauro\ladybug_tools/python/Lib/site-packages
[12002] C:\\Users\\Mauro\\ladybug_tools\\python\\python.exe" started, arguments: "-m ladybug_rhino set-python-search --python-package-dir C:\\Users\\Mauro\\ladybug_tools/python/Lib/site-packages
[12193] Setting Rhino IronPython search path ...\r\nCongratulations! Setting the search path in the following file was successful:\r\nC:\\Users\\Mauro\\AppData\\Roaming\\McNeel\\Rhinoceros\\6.0\\Plug-ins\\IronPython (814d908a-e25c-493d-97e9-ee3861957f49)\\settings\\settings-Scheme__Default.xml\r\n
[12194] Done
[12194] backup grasshopper operation: Execute
[12194] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, copy-gh-components, C:\Users\Mauro\ladybug_tools/grasshopper, UNDOEXECUTE, C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, remove-gh-components
[12194] Done
[12194] perform grasshopper operation: Execute
[12195] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, copy-gh-components, C:\Users\Mauro\ladybug_tools/grasshopper, UNDOEXECUTE, C:\Users\Mauro\ladybug_tools\python\python.exe, -m, ladybug_rhino, remove-gh-components
[12200] C:\\Users\\Mauro\\ladybug_tools\\python\\python.exe" started, arguments: "-m ladybug_rhino copy-gh-components C:\\Users\\Mauro\\ladybug_tools/grasshopper
[12513] Copying Grasshopper Components ...\r\n
[13308] UserObjects removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\ladybug_grasshopper\r\nUserObjects removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_core\r\nUserObjects removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_energy\r\nUserObjects removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_radiance\r\nUserObjects removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\dragonfly_grasshopper\r\nUserObjects copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\ladybug_grasshopper\r\nUserObjects copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_core\r\nUserObjects copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_energy\r\nUserObjects copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\honeybee_grasshopper_radiance\r\nUserObjects copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\UserObjects\\dragonfly_grasshopper\r\nComponents removed from: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\Libraries\\ladybug_grasshopper_dotnet\r\nComponents copied to: C:\\Users\\Mauro\\AppData\\Roaming\\Grasshopper\\Libraries\\ladybug_grasshopper_dotnet\r\nCongratulations! All component packages are copied!\r\n
[13308] Done
[13309] backup grasshopper operation: License
[13309] - arguments:
[13309] Done
[13309] perform grasshopper operation: License
[13311] Done
[13314] Instalando componente Set up openstudio
[13314] backup finishing operation: Execute
[13314] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, C:\Users\Mauro\ladybug_tools/setup.py
[13314] Done
[13314] perform finishing operation: Execute
[13315] - arguments: C:\Users\Mauro\ladybug_tools\python\python.exe, C:\Users\Mauro\ladybug_tools/setup.py
[13320] C:\\Users\\Mauro\\ladybug_tools\\python\\python.exe" started, arguments: "C:\\Users\\Mauro\\ladybug_tools/setup.py
[25748] Cleaning: C:\\Users\\Mauro\\ladybug_tools\\temp\r\nExtracting openstudio\r\n
[25748] Done
[25755] Warning: Found binary data file "C:\\Users\\Mauro\\ladybug_tools/maintenancetool.dat" but deliberately not used. Running as installer requires to read the resources from the application binary.
[25756] Writing maintenance tool: "C:\\Users\\Mauro\\ladybug_tools/maintenancetool.exe.new"
[25756] Escribiendo la herramienta de mantenimiento.
[25800] Wrote permissions for maintenance tool.
[25945] Maintenance tool restart: false.
[25946] Instalación completada.
Done
Instalando componente Finish
Is install: True
Is install: True
Done
