Hi all
I have a problem with the HB Peak Loads
component.
Any idea what this message means or how to check what is wrong with the input file?
Hi all
component.
Hi @martin6! Thank you for posting this issue. As usual, if you can share the input file it will be much easier for us to help with this issue.
I would check the .err
file to see what is the full error message.
@mostapha here is the file 018_18…
The .err
is usefull. Thanks for the reminder. Will need a while till I have this checked and report back…
the file is also the base for this PMV run which failed. Do you have any idea why?
Looks like in case of this calculation E+ is unable to deal with internal window shades, or maybe the way they where set in this case.
Removed them, now the component works.
