HB Opaque Material - Not Working in an Assembly
I am trying to establish a wall assembly using the create material component (HB Opaque Material) in order to be able to adjust the parameters of that materials for testing its impact on energy use. I have been able to run the simulation no problem but for whatever reason it reads in the first material but ignores the rest. Am I missing something fundamental here? Or perhaps there is an easier way to adjust material thicknesses with library components.
Also, is it possible to mix library material (using the search library component in HB) AND custom materials? That wasn’t working either.
Hope that is clear, thanks!
Hi @awnyxx, This is a Ladybug Tools related question and should be posted to Ladybug Tools forum.
