Hi @mingbo, is there a way to name the model hbjson files in a sequential order (e.g. “model 1”, “model 2”…) instead of just having the unnamed name?
My understanding is that the only way to get different hbjson files is just leaving the “name” input of the model empty (which gives the unnamed_xxxxxxxx.hbjson as in the screenshot below).
Leaving the “name” input empty works in terms of not getting the same results (because the hbjson files are different), but still it shows the same “unnamed” model name, which makes it impossible to find the correspondence between the model name and the hbjson file (rephrasing: trying to match the elements in the list on the left with the ones in the list on the right - the two lists are not in the same order)
