Keyboard shortcuts and repeated actions
I may have missed it somewhere, but are there keyboard shortcuts for any of the actions I have to do repeatedly during “cleanup” phase? I found myself repeating align, pull to room, and merge rooms a lot and wishing there was a shortcut for either those specific actions or a “repeat the same thing I just did but for these rooms” shortcut. Is there a master list of all the shortcuts somewhere that I can look at, too?
Emily
Hi @eschwartz,
We don’t currently have keyboard shortcuts for these commands. We probably should. To be honest, the main challenge has been to come up with a good list of keyboard shortcuts for each command. I used to have a list but then I gave up at some point. Maybe we should bring it back up on the list.
cc: @antonellodinunzio
This one is already supported. You can press Ctrl + Enter. You can also the last used command in the UI. It uses the last input values that you used for the command.
Not directly related to your question but just to be sure, you are aware of the Auto Align command. Right?
Yes- I know about the auto align command and use it- usually first action I take! There were a lot of weird holes that were on the edge of rooms (not in the center so they couldnt be filled/deleted), so instead of deleting vertices, pull to room was more effective
Got it! I usually use the Remove Short Segments command for those cases. The limitation is that it will only work nicely if you don’t have other short segments that should be kept in the model.
