Linked Revit rooms not pulling through
Hi @milog, great stuff!
Just so you know, you can do all the copying inside the Model Editor, and before going to Rhino.
This could be a very interesting utility that I never of. In theory, we can use a similar workflow that we currently use to compare the same level of different models for comparing the levels in the same building.
The main challenge is that you will still need to export the rooms to be able to compare them. What do you think about this, @chriswmackey? This will probably be much easier to do once we implement the new workflow to speed up the process of exporting the rooms from Revit to Model Editor.
Nice! You are ahead of us here. :slight_smile: I’m glad that this approach is working for you in the Rhino plugin! We plan to provide a similar workflow in the Model Editor so you can accomplish the same without the need to use the Rhino plugin.
