I’m trying out the trial, and going through some of your how-to info. I’m working in an MEP model with an architectural link, but when I look at the “Links” drop-down, it appears empty.
Thanks in advance!
Thanks in advance!
Hi @wilkinsonam, welcome to the forum.
See here:
Thanks @mostapha – giving this a try now.
The links were all loaded when I tried previously. I rebooted in case that helps anything on Revit’s end.
This time around, the model loaded with the architectural link missing. I’ve loaded it, and can confirm I’m seeing geometry from it.
Pollination is warning me about working on a detached central model. After clicking “Reload Settings”, I see “Host” in the list now, but still no links.
I’ve saved the host as a central model and will reload a local.
The new local opened with the link properly loaded. The Links list is again “” when opening Windows/Doors. Clicking “Reload settings” populates the list – I now see Host and the architectural link.
Thank you for documenting this, @wilkinsonam!
Just in case, here is the documentation for setting up linked models correctly for Pollination.
