Hello -
PO_DrawRoom does not seem to consider the entered elevation from last time command was used.
16 ft elevation is shown from last time command was used, but it’s drawing at 0 ft
room drawn at 0 ft elevation
Rhino Plugin info
Hello -
Rhino Plugin info
Thank you for reporting this, @victorbrac - This is one for @mingbo to check.
I can recreate the error. @mingbo, FYI, if I re-input the same value manually everything works as expected.
I found the same. But still decided to report the bug!
This bug is fixed in version 1.11.0. Thank you for reporting the bug, @victorbrac!
