# Pollination - First time using, couple questions
**URL:** <https://discourse.pollination.solutions/t/pollination-first-time-using-couple-questions/29492>\
**Category:** Grasshopper Plugin\
**Tags:** question\
**Created:** [September 30, 2026, 5:29pm UTC](https://discourse.pollination.solutions/t/pollination-first-time-using-couple-questions/29492 "2026-09-30T17:29:54Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![mostapha](https://discourse.pollination.solutions/user_avatar/discourse.pollination.solutions/mostapha/32/5761_2.png) [@mostapha](https://discourse.pollination.solutions/u/mostapha)\
**Post date:** [September 30, 2026, 6:01pm UTC](https://discourse.pollination.solutions/t/pollination-first-time-using-couple-questions/29492/2 "2026-09-30T18:01:49Z")
</div>
👋 Hi @vitorleiteg, good to see you back and welcome to the Pollination forum.
See my responses below, and let me know if you have any other questions.
> [@vitorleiteg](#):
> Lot’s of Phius work here in New England which unfortunately got me tied to other modeling tools for the past 3-4 years.
We should make our support for PH official so you could also use it for your projects! We have been waiting to finish full support for program types and constructions which is almost done. 🙂
> [@vitorleiteg](#):
> 1. Are the PO Schedule, PO Room, etc. Grasshopper components exclusive to Pollination Rhino?
Yes. They are part of the Pollination Rhino plugin.
> [@vitorleiteg](#):
> 1. Is the ability to ‘Pollinate’ through the cloud exclusive to the paid tiers?
We don’t offer cloud simulation anymore. You can change it to run the studies locally, however. This video covers different ways that you can run simulations using the Pollination model:
> [@Running the model? No Run Simulation](https://discourse.pollination.solutions/t/running-the-model-no-run-simulation/29316/5):
> Hi Neil, You are right and our UI doesn’t allow you to create a private project without compute resources, but you can create a project under your user profile which will be enough for running the simulation locally. Here is a recording that shows the 3 possible workflows: Exporting the model to an IDF file. Running the energy simulation inside Rhino. Loading the model into Grasshopper and running the simulation inside Grasshopper. Let me know if you have any questions.
> [@vitorleiteg](#):
> 1. When running locally, should the ‘check study status’ and ‘check run results’ work by just connecting them to the ‘pollinate’ component?
Yes. They should. Are you facing any issues for running your studies locally?
> [@vitorleiteg](#):
> 1. I’m doing this analysis for a change-of-use (commercial to mixed-use residential) of a historical building. Is there a way to prevent the Appendix G recipe from changing my envelope assemblies to the baseline R-values?
This and your next question about the recipe are questions for @chriswmackey. I will assign the topic to him so he can help you for your questions.
> [@vitorleiteg](#):
> Terrific work you all have done with this tool! Lots of improvements to what I already considered the best dynamic energy modeling tool.
Thank you so much for the kind words. Since some of the available online documents are outdated and you might not have seen the latest announcements, we are slowly but surely phasing out the simulation part out of Pollination and focusing on everything before and after running the simulation. That includes all the steps involved preparing your simulation model such as geometry, program types, thermal zones, constructions, etc.
We already started migrating most of the Pollination recipes to Ladybug Tools. See here:
> **[We are Adding 5 New Daylight Compliance Recipes to Ladybug Tools](https://discourse.ladybug.tools/t/we-are-adding-5-new-daylight-compliance-recipes-to-ladybug-tools/40514)**
> Hello Ladybug Tools community, As we announced earlier this year, as part of our goal of further integrating the LBT Grasshopper plugin with the needs of large professional projects, we are starting to expose new recipes for several standard...
Thank you and let me know if you have any follow up questions.
_[View the full topic](https://discourse.pollination.solutions/t/pollination-first-time-using-couple-questions/29492)._
