Pollination Run
All my simulations are done based on the results I got but it says CANCELLED which am not sure what does it mean. Could you help me why it does not show completed rather than cancelled?
Hi @mahagh, this is one of those 1 in 10,000 cases! It has happened because you reached the maximum (3 hours) CPU usage on your free account after running this study and Pollination tried to cancel the study but it happened to be right after all the studies were finished.
I updated the status to completed.
Thanks @mostapha for clarification.
Just to make sure, to avoid this issue happens again, is there any other way to run my parametric simulations other than buying the cloud subscription?
Thanks
Hi, @mahagh - Yes. You can run them locally too. It will run them one at a time but it will work.
To do that, right-click on the Pollinate component
The small icon on the component will change to a desktop. Make sure to check the Local run settings before running the simulations.
