# Rhino Plugin Installation Error "ID already in use"
**URL:** <https://discourse.pollination.solutions/t/rhino-plugin-installation-error-id-already-in-use/3529>\
**Category:** Rhino Plugin\
**Created:** [January 23, 2024, 4:38pm UTC](https://discourse.pollination.solutions/t/rhino-plugin-installation-error-id-already-in-use/3529 "2024-01-23T16:38:30Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![mostapha](https://discourse.pollination.solutions/user_avatar/discourse.pollination.solutions/mostapha/32/5761_2.png) [@mostapha](https://discourse.pollination.solutions/u/mostapha)\
**Post date:** [January 23, 2024, 6:48pm UTC](https://discourse.pollination.solutions/t/rhino-plugin-installation-error-id-already-in-use/3529/2 "2024-01-23T18:48:36Z")
</div>
Hi @jroberts,
Thank you for preparing for the workshop in a month to come! It deserves a trophy! 🥇 🙌
The error is not related to the license. It is most likely because the plugin is already loaded from another place on your machine. Try to clean the registry and the issue should be resolved.
See here for a similar issue.
> **[Pollination Rhino Installer for Rhino 8](https://discourse.pollination.solutions/t/pollination-rhino-installer-for-rhino-8/3330/8)**
> I got an error after changing to net frame work. Though its seems plugin is loaded correctly in rhino and grasshopper but this error pops up every time Showing this error The error is not there when opening in RHINO 7
_[View the full topic](https://discourse.pollination.solutions/t/rhino-plugin-installation-error-id-already-in-use/3529)._
