Hi Folks,
Runs with models that have SHW assigned (HB SHW System Component) fail. I cannot pin point anything else causing them to fail. And local LBT simulations (with SHW assigned) run successfully.
For example this run: 169c6e95-10ba-5faf-a269-76828ed64468
Hey @patrykwozniczka ,
What version of which recipe did you use? The custom-energy-sim recipe didn’t have support for SHWSystems until today. The annual-energy-use one should be good to go.
Ah, I found the bug. Thank you for reporting this. I am pushing a fix now and I’ll let you know when the recipe on Pollination is ready to run.
