Sensor grids outside the building facade
Does anybody having some additional vertical sensor grids when generating sensor grids for the spaces?
Pollination configuration
Levent
Hi @hlkocalioglu,
This is because we added support for creating sensor grids from walls and apertures. Can you try to lock/hide the apertures before creating the sensor grids?
That being said, I agree with you that we should probably be more explicit about those choices in the command and allow the user to filter them by type.
FYI hiding apertures solved the problem @mostapha.
