before I forget it again. Floors are not assigned when PO_AddRoomsByLayer
is used
Thanks @martin6, Can you provide a little bit more context here? By Floor
do mean the Floor
type for faces or are you referring to Story
for each room?
Sorry for my lack of proper use of Ladybug elements in the first place.
I’m referring to Story
. Here the rooms where generated using PO_AddRoomsByLayer
exept for the last two which where modified and added using PO_AddRooms
Thanks @martin6, I just fixed this issue and a new version will be released later today.
A new developer’s version 0.125.1 has been released with this fix.
