Hi All,
I have been using the pollination imageless glare recipe with a radial sensor grid for a sports hall design with some clestory windows.
I would like to be able to find the worst performing hours of the year (DGP wise) so that I can use these to generate radial DGP plots for the worst performing times of the year. My current .dgp results are 6400 x 8760 values edit: it is 6400 x 4890. The option I can currently think of is reading the .dgp result into a python data frame and python from there to retrieve the worst HOYs then manually feeding these back into HB Annual Results HOYs in grasshopper.
I have tried
- Using HOYs with no HOY input; this gives me only the first row of the DGP file.
- Using HB annual results to data; this seems to just give the header/description of each row but not the data.
- Reading .dgp with the open file component; which crashes gh/rhino.
Any ideas on a way to accomplish this within grasshopper or is this better done via python?
Jack
