Thank you so much @chriswmackey for this brilliant recipe!
I was trying to run the sample Dragonfly file and the simulation battery shows this error - 1. Handler-python: cannot import emissions from pollination_handlers.inputs
What does that error mean? I’ve changed nothing from the sample file.
Your plugin is still not up-to-date, @shrutis . Make sure that you are using the latest single-click installer or you are running the LB Versioner to get the latest version.
