Hi @mostapha, I’m having some issues converting some of the rooms into 2D views on the web editor after exporting from Revit. Is there any reason why this would happen?
Hi @saeedsz, welcome to the forum!
I’m afraid you’re post doesn’t provide enough information for me to be able to help you.
- What are the exact issues you’re facing?
- Does the model pass the validation check?
- Can you share a screenshot that shows the error?
- Can you share your exported model from Revit?
- The problem is not all the rooms convert to 2D in the cloud editor so I can’t align the rooms and make other adjustments.
- It doesn’t pass the check, likely due to the problem above.
- I can’t upload attachments cause I’m a new user but I’ll send you an email with the exported model and screenshot.
Thank you.
Hi @saeedsz,
This is most likely happening because you are using the “Full Volume” option instead of using the “Extruded Floors” for geometry calculation.
Changing all the floors to extruded floors should solve the problem.
