I am exploring how to build Streamlit apps that integrate with the Ladybug Tools ecosystem, focusing on creating a single Streamlit-VTK.js viewer capable of displaying multiple Analysis Geometries simultaneously.
Specifically, I want to combine the following in a single viewer:
- Model View: Surfaces categorized by type.
- Daylight Results: Colored grid meshes. [DA150, DA200, DA300]
- Window Solar Radiation: Colored window meshes. [Different Seasons]
- Any other combination of meshes and data.
So far, I have successfully added multiple datasets to a specific Analysis Geometry using ladybug_display.visualization (e.g., multiple datasets for daylight analysis). However, I haven’t found a way to display multiple Analysis Geometries within the same VTK.js container. Currently, I’m forced to create a separate viewer for each Analysis Geometry, which significantly slows down my app.
I have reviewed most of the sample apps in the Pollination Apps GitHub repository, but I haven’t found a solution to this issue.
I’d appreciate any guidance on whether combining multiple Analysis Geometries in a single VTK.js viewer is possible. If it’s not feasible, are there alternative methods for visualizing these results efficiently?
