Annual Daylight Run Missing Results Output
Hey Community,
I’m an old hat at Ladybug but new to Pollination. I’m trying to run an annual daylight study. I’ve noticed 2 recipes (0.1.10-viz and 0.1.15-viz)…I asssume the second one is the latest. What I’m confused about is where are the"Results" output for the latest version? Is there another way of extracting these from the 0.15 version to plug into the Ladybug components? Is there a reason they are not included?
TIA
Hi @acrhidan, and welcome to the :pollination: forum.
This is by design to improve the speed for running the recipe. If you want to access the results folder as an output you should use the recipe with the full tag. See Mikkel’s answer here:
You can read more about the changes to the recipes here:
Thanks Mostapha. Makes sense.
