Annual Energy Use-Not applying HVAC
Hi @mostapha @chriswmackey,
I’m trying to run a simulation with annual-energy-use.
Everything runs fine when I run locally, but when I send the same HB model to pollination the model runs with no HVAC system. I’m using annual-energy-use 0.5.5. Honeybee v 1.6.2.
I attached the HBJson submitted to the recipe.
111023_1731_CornerstoneWarehouseNECB_existing.hbjson (315.7 KB)
Cameron
Hi @cameron-lawrence ,
Sorry that this issue is likely the result of the fact that I have not updated the annual-energy-use recipe in a month or so. @mingbo had been implementing a lot of fixes in Ironbug and I was waiting for things to stabilize before I updated the recipe. We haven’t had a bug report about it in three weeks so I would say it’s probably stable now.
I’ll push a new version later today and let you know when you can run a simulation with your new model.
I just pushed an updated version of the annual-energy-use recipe (version 0.5.6). I verified that it runs correctly with your sample model with this test here on Pollination.
So just use version 0.5.6 of annual-energy-use and you should be good to go.
@chriswmackey thanks so much for the help!
A post was split to a new topic: Adding NECB K schedules to default schedules
