Annual Radiation Not Showing Visualization
I am trying to run “Annual Radiation” on my model through the Rhino App. I ran it on the cloud. However, I don’t see any visualization for it available. All I can see for the results are json, .txt and .ill files. It’s the same when I want to load the result in my Rhino model. Am I doing something wrong?
Hi @monahmi, you are not doing anything wrong. See this topic here:
If you use the [Annual irradiance]( Pollination Cloud App) instead of the annual radiation it generates VisualizationSets that you can load in Rhino easily with the components that are discussed in the other discussion.
Thanks a lot @mostapha. That was helpful!
