Hi there,
i am starting to look into pollination cloud so excuse if the question does not really fit here…
I am trying to find a way to use a very roughly meshed model (for example osm / cityjson etc) with pollination cloud without the use of rhino / gh etc. the problem i see so far is, that i do need some kind of remeshing to at least a sensor grid where i then would be able to run the simulation on.
Does pollination cloud provide any tools / features to use just plain meshes? or remesh? or would i have to do the meshing/sensorgrid generation?
Obviously, it is up to you how the logic should be and what kind of post-process you are looking for for 1.
For example, this is a function based on honeybee-grasshopper-radiance that uses honeybee-core, honeybee-radiance and ladybug-geometry where grids are generated by floors.
def create_room_grids(rooms: List[Room],
grid_size: Optional[float]=1,
dist_floor: Optional[float]=0.8,
remove_out: Optional[bool]=True,
wall_offset: Optional[float]=0.0):
# TODO: add advanced quad only
x_axis = None
# create lists to be filled with content
grid = []
clean_rooms = []
for obj in rooms:
if isinstance(obj, Model):
clean_rooms.extend(obj.rooms)
elif isinstance(obj, Room):
clean_rooms.append(obj)
else:
raise TypeError('Expected Honeybee Room or Model. Got {}.'.format(type(obj)))
for room in clean_rooms:
# get all of the floor faces of the room as Breps
lb_floors = [face.geometry.flip() for face in room.faces if isinstance(face.type, Floor)]
if len(lb_floors) != 0:
# create the gridded ladybug Mesh3D
# if quad_only: # use Ladybug's built-in meshing methods
if x_axis:
lb_floors = [Face3D(f.boundary, Plane(f.normal, f[0], x_axis), f.holes)
for f in lb_floors]
lb_meshes = []
# TODO: generate a log file for mesh grids errors
for geo in lb_floors:
try:
lb_meshes.append(geo.mesh_grid(grid_size,
offset=dist_floor))
except AssertionError as e:
print(e)
continue
lb_mesh = lb_meshes[0] if len(lb_meshes) == 1 else Mesh3D.join_meshes(lb_meshes)
# remove points outside of the room volume if requested
if remove_out:
pattern = [room.geometry.is_point_inside(pt)
for pt in lb_mesh.face_centroids]
try:
lb_mesh, vertex_pattern = lb_mesh.remove_faces(pattern)
except AssertionError: # the grid lies completely outside of the room
lb_mesh = None
# remove any sensors within a certain distance of the walls, if requested
if wall_offset and lb_mesh is not None:
wall_geos = [f.geometry for f in room.faces if isinstance(f.type, Wall)]
pattern = []
for pt in lb_mesh.face_centroids:
for wg in wall_geos:
if wg.plane.distance_to_point(pt) <= wall_offset:
pattern.append(False)
break
else:
pattern.append(True)
try:
lb_mesh = None
if lb_mesh is not None:
# extract positions and directions from the mesh
base_poss = [(pt.x, pt.y, pt.z) for pt in lb_mesh.face_centroids]
base_dirs = [(vec.x, vec.y, vec.z) for vec in lb_mesh.face_normals]
# create the sensor grid
s_grid = SensorGrid.from_position_and_direction(
clean_rad_string(room.display_name), base_poss, base_dirs)
s_grid.display_name = room.display_name
s_grid.room_identifier = room.identifier
s_grid.mesh = lb_mesh
s_grid.base_geometry = \
tuple(f.move(f.normal * dist_floor) for f in lb_floors)
# append everything to the lists
grid.append(s_grid)
return grid
