In the Revit Plugin (2.124.0.0), when I get to the end, I click export to IDF or export to gbXML, but both produce an hbJSON output. Is this known / expected?
@corymosiman12 this is likely a bug. Can you share your model or do a screen recording so we can retrace your steps?
Ah! This is a bug and I should have caught it before the release. I can create this error using the sample model. That’s my bad! Thank you, @corymosiman12 fo reporting it.
@ksobon, all the different export extensions are HBJSON files renamed to XML, IDF, etc! I imagine this is because we removed the DFJSON option and now the links are broken.
Okie dokie, lovely, no worries. Glad I’m not crazy
This has been fixed and the new release (version 2.125.2) is available to download on Pollination.
Thank you @corymosiman12 for reporting the issue and thank you @ksobon for the quick fix!
