The base offset is not edited for all selected layers, so all have to be edited manually.
Hi @crduggin, Thanks! I can’t recreate this issue on my end.
Does Revit give you any errors? If it didn’t work you can also select all these rooms in Revit, and adjust the number there. In that case, you have to go back one step and return to see the change.
