Hi, I ran the simulation and it was successful. However, in the outputs I cannot find the Visualization folder. I need to load the results in Rhino to visualize the Daylight analysis. Is there any way to fix it?
Thanks.
Hi @atika,
If this is the simulation you are referring to, it has failed and @chriswmackey will be able to help in debugging why it failed.
Currently, only the annual-daylight recipe shows visualization on Pollination.
Hi @atika . There is another recipe with annual daylight 8.8viz written. Then only you could see visualisation output.
Thank you so much @asisnath. Now I can see the visualization output.
