I tried changing Energy Simulation Parametes.
I checked several models, but changes to any paremeter in the panel above are not reflected in idf files.
Hey @keigonomura ,
Can you elaborate on which property of the Simulation Parameter is not reflected in your IDF? Can you also clarify which method you are using to save the IDF?
I replicated your changes to the simulation parameter:
… and then I used “Save As IDF” and all of the properties seem to have translated correctly:
@chriswmackey This case.
I lost the original Rhino file.
When I opened it, I got the following error message, and the all the properties have been reset.
Test.3dm (260.4 KB)
I may have set the Maximum Figures in Shadow Overlap Calculations less than 200 before I saved the Rhino file for the last time. This would be another issue.
Meanwhile, I tried to reproduce the issue with a different Rhino file, and the Energy Simulation Parameters were reflected successfully. So, this issue is solved for now. I may have been mistaken.
Thanks @keigonomura ,
The fact that you were able to set the maximum figures to something less than 200 in the Rhino UI is a bug on our end.
@mingbo can fix it when he gets the chance.
