"Check Run Results" output wrong file location
When I run a recipe locally with the Setup Runs the Check Run Results exports file paths that don’t exist. Is this a user error on install? or something deeper in the code?
This is where it really lives
C:\Users[username]\simulation[projectname][projectnam\metrics\cda
This is the output from the Check Run Results
C:\Users[username]\simulation[projectname]/cda#cDA
the output file path doesn’t let me get to the data, the other path allows me to visualize the data once the files are read. I also had to set view subfolders to True in order to access the *.cda files, with it set to False only the config.json is available.
Am I completely out of line and missing something?
Thank you,
-Ren
Mingbo, can you try to recreate this on your end. Thank you!
Hi @renrainville - Thank you for reporting the issue. Can you also share the version of the Pollination Grasshopper plugin that you are using?
1.18.3.0, I have the 1.19.2.0 installer downloaded from last week. I will install the update and follow up.
same situation with 1.19.2.0
