Conditional Thresholds on Ladybug-hourlyplot not working
Hi @mostapha, @chriswmackey , and @dev,
I am trying to plot the hourly chart using the conditional statement thresholds and it was working fine before but now its not!
from ladybug.epw import EPW
from ladybug.legend import LegendParameters
from ladybug.hourlyplot import HourlyPlot
from ladybug.analysisperiod import AnalysisPeriod
from ladybug.datacollection import HourlyContinuousCollection
from plotly.graph_objects import Figure
epw_file = r'C:\ladybug\AUS_QLD_Brisbane.945760_TMYx\AUS_QLD_Brisbane.945760_TMYx.epw'
global_epw = EPW(epw_file)
_wea_data = global_epw.import_data_by_field(6)
def get_hourly_data_figure_conditional(_hourly_data: HourlyContinuousCollection, st_month: int, st_day: int, st_hour: int, end_month: int,
        end_day: int, end_hour: int) -> Figure:
    lb_ap = AnalysisPeriod(st_month, st_day, st_hour, end_month, end_day, end_hour)
    _hourly_data = _wea_data.filter_by_analysis_period(lb_ap)
    hourly_plot = HourlyPlot(_hourly_data)
    return hourly_plot.plot(title=str(_hourly_data.header.data_type), show_title=True)
filtered_hourly_data= _wea_data.filter_by_analysis_period(AnalysisPeriod(1,1,0,12,31,23))
data_work_hours = filtered_hourly_data.filter_by_conditional_statement('a>={} and a<={}'.format(21,24))
Hourly_conditional_figure = get_hourly_data_figure_conditional(data_work_hours, 1, 1,
                0, 12, 31,
                23)
I guess there might be sth wrong with the latest ladybug.hourlyplot module.
Thanks
Amir
I Will look into this
Sorry for the delay in responding to this @amirtabadkani.
I believe there is a bug in the snippet you shared. I added some comments to your code snippet. Please let me know if I missed something.
# The data type of the _hourly_data argument here should be HourlyDiscontinuousCollection
    # You are overriding the function argument here and assigning it a new value.
    # Did you mean to apply the filter on the _hourly_data instead of _wea_data?
                0, 12, 31,
                23)
GPT 3.5 also identified this correctly. The following is its response when I dropped your original message.
It seems there’s a problem with your code structure. You’re overwriting the _hourly_data variable within the get_hourly_data_figure_conditional function. Since you’re filtering data based on certain conditions, it’s recommended to use a different variable name to avoid confusion.
Let’s refactor the code to fix this issue:
    filtered_hourly_data = _hourly_data.filter_by_analysis_period(lb_ap)
    hourly_plot = HourlyPlot(filtered_hourly_data)
    return hourly_plot.plot(title=str(filtered_hourly_data.header.data_type), show_title=True)
filtered_hourly_data = _wea_data.filter_by_analysis_period(AnalysisPeriod(1,1,0,12,31,23))
                0, 12, 31,
                23)
In this version, I’ve changed _hourly_data to filtered_hourly_data within the get_hourly_data_figure_conditional function to avoid overwriting the original data. Now, it should work as expected.
Thanks @devang - you re completely right - :slightly_smiling_face:
