Construction Manager Error: Object reference not set to an instance of an object
I am creating a new construction from scratch in the Construction Manager. I have create several Materials by duplicating existing Materials that were close and setting my own thickness and conductivity. However, when I combine these materials into a Wall Assembly I receive the following error:
System.NullReferenceException: Object reference not set to an instance of an object.
   at System.Object.GetType()
   at HoneybeeSchema.Extension.AddMaterial(ModelEnergyProperties modelEnergyCollection, IMaterial material)
   at HoneybeeSchema.Extension.AddMaterials(ModelEnergyProperties modelEnergyCollection, IEnumerable`1 materials)
   at Honeybee.UI.ConstructionViewData.CheckResources(ModelEnergyProperties libSource)
   at Honeybee.UI.ConstructionManagerViewModel.AddUserData(IConstruction item)
   at Honeybee.UI.ConstructionManagerViewModel.ShowConstructionDialog(IConstruction c)
   at Honeybee.UI.ConstructionManagerViewModel.<get_AddOpaqueConstructionCommand>b__16_0()
   at Eto.Forms.RelayCommand`1.Execute(Object parameter)
   at Eto.Forms.MenuItem.OnClick(EventArgs e)
   at Eto.Forms.MenuItem.Callback.OnClick(MenuItem widget, EventArgs e)
   at Eto.Wpf.Forms.Menu.MenuItemHandler`3.OnClick() in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Menu\MenuItemHandler.cs:line 34
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.ShowDialog()
   at Eto.Wpf.Forms.DialogHandler.ShowModal() in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\DialogHandler.cs:line 60
   at Pollination.RH.RhinoCommands.PO_EnergyConstructions.ResourceManager(RhinoDoc doc)
   at Pollination.RH.RhinoCommands.PO_EnergyConstructions.RunCommand(RhinoDoc doc, RunMode mode)
Here is the Construction Schema:
  "type": "OpaqueConstructionAbridged",
  "materials": [
    "Stone Face 8in",
    "Generic Brick 12in",
    "Wall Air Gap 1in",
    "Clay Blocks 4in",
    "Gypsum Or Plaster Board 1in"
  "identifier": "New Opaque Construction fec27",
  "display_name": "Yale Kirtland Hall"
Stone Face
  "roughness": "MediumRough",
  "type": "EnergyMaterial",
  "thickness": 0.2032,
  "conductivity": 2.5,
  "density": 1920.0,
  "specific_heat": 790.0,
  "thermal_absorptance": 0.9,
  "solar_absorptance": 0.65,
  "visible_absorptance": 0.65,
  "identifier": "Stone Face 8in",
  "display_name": "Stone Face 8in"
Brick
  "thickness": 0.3048,
  "conductivity": 0.9,
  "density": 1920.0,
  "identifier": "Generic Brick 12in",
  "display_name": "Generic Brick 12in"
Air Gap
  "roughness": "Smooth",
  "thickness": 0.0254,
  "conductivity": 0.667,
  "density": 1.28,
  "specific_heat": 1000.0,
  "solar_absorptance": 0.7,
  "visible_absorptance": 0.7,
  "identifier": "Wall Air Gap 1in",
  "display_name": "Wall Air Gap 1in"
Clay Blocks
  "roughness": "MediumSmooth",
  "thickness": 0.1016,
  "conductivity": 1.0,
  "density": 1800.0,
  "specific_heat": 920.0,
  "identifier": "Clay Blocks 4in",
  "display_name": "Clay Blocks 4in"
Plaster
  "conductivity": 0.57961212171595045,
  "density": 800.00182919117651,
  "specific_heat": 1089.2971854559414,
  "identifier": "Gypsum Or Plaster Board 1in",
  "display_name": "Gypsum Or Plaster Board 1in"
Hi @justinshultz, this was an issue in the older version, have you tried the new version? I did a test with your data here, I can’t reproduce this issue.
Hi @mingbo, I downloaded and reinstalled the plugin from the below post last week. Is the download link not updated? If not, where can I always find the most recent download?
Hi @justinshultz, it is the same link. It always points you to the latest installer.
@mingbo I have reinstalled the Rhino Plugin and noticed several UI changes right away. I must have still been running an older version of the Rhino Plugin. Hopefully the new Plugin will alleviate the problems I had. Thank you for bringing to my attention that I was running an older version unexpectedly.
Please let me know if everything works as expected.
No problems with the Construction Manager using the new plugin. Thank you all for the hard work!
