Something with the context shades is causing my model to fail to export to GEM.
Hi @crduggin, thank you for the update. Can you export the model as a HBJSON and share it with me? That way I should be able to recreate the issue on my end.
Ideally, include the problematic shades too.
How do i export to HBJSON?
Hi @crduggin, it is the same process. Just select the Honeybee Model (*.hbjson) at the last step.
You can also share the Revit model with me if that makes it easier for you! Thanks again.
@crduggin, I had a closer look to the original error and the initial errors comes from an older version of the plugin. It should not be a problem anymore. I’ll mark this topic as solved for now.
We can continue the conversation about the non-planar shades’ translation in the private message.
