Copying/ Editing multiple windows across different zones
Hi team,
I trying to edit multiple windows across different zones, essentially two things:
  1. Copy windows of zone to another
  2. Selecting multiple windows and scaling them to required size.
    But I am not able to do that without changing the size of the associated zone.
    Could you please suggest the best way to do this.
    Thanks.
Hi @ishitasingh,
Try the PO_DupAperturesDoors command.
I don’t think we have a good solution for that yet. It has been discussed here:
Thanks, @mostapha . The linked post is helpful. Considering that windows can be scaled and modified as native Rhino geometry until they are assigned as apertures. Is there a way to convert pollination apertures back to Rhino geometry?
So essentially, I can modify them in place and then reassign them as apertures?
Thanks.
Hi @ishitasingh you can use PO_RemoveProperties command, and it will convert it back to native Rhino geometry. However, you can also scale the apertures directly with Rhino commands after you turn off the RoomSelection mode.
