Could room manager program display current loads when deselected
Hello! we all know the room editor:
Now when one of those loads are deselected they show a blank value, such as the electrical loads
Could it be be possible when the load’s By Room Program Type are deselected, that the current load in the program be displayed rather than a blank value?
Use cases for me are QAQC and knowing what the current programs loads are to double check if they are correct, as the Program Type Manager only shows the absence or the presence of loads within the program type.
All the best
-Trevor
@tfedyna, that’s a limitation. Let’s see what @mingbo says but our overall approach is to develop a new UI from scratch to address these limitations. The current UI is not good enough.
Sounds good to me! And I think the current ui is quite nice for what its worth
-trevor
Ha, thanks @tfedyna, I think you are the first one saying this.
I totally agree with you that it would be nice to include the current load value, and it makes easier to debug the room. But this is bit too much of work to update the current UI for now. We will definitely address it in the new UI.
Thanks @mingbo! I’m looking forward to exploring all the new stuff in the new UI when the time comes that its released!
