Thanks! Now I can recreate the issue both in Rhino and Revit.
@mingbo, here is the error message.
PO.V1.36.0.0 (Oct 30, 2023)
System.NullReferenceException: Object reference not set to an instance of an object.
at HoneybeeSchema.EnergyWindowMaterialGlazing.ToString(Boolean detailed)
at Honeybee.UI.Dialog_Construction.<>c__DisplayClass31_1.<.ctor>b__9(Object s, EventArgs e)
at Eto.PropertyStore.TriggerEvent[T](Object key, Object sender, T args)
at Eto.Forms.Grid.OnSelectionChanged(EventArgs e)
at Eto.Forms.Grid.Callback.OnSelectionChanged(Grid widget, EventArgs e)
at Eto.Wpf.Forms.Controls.GridHandler`2.<AttachEvent>b__22_4(Object sender, SelectedCellsChangedEventArgs e) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\GridHandler.cs:line 209
at System.Windows.Controls.DataGrid.OnSelectedCellsChanged(SelectedCellsChangedEventArgs e)
at System.Windows.Controls.DataGrid.NotifySelectedCellsChanged()
at System.Windows.Controls.DataGrid.ChangingSelectedCellsHelper.Dispose()
at System.Windows.Controls.DataGrid.MakeFullRowSelection(ItemInfo info, Boolean allowsExtendSelect, Boolean allowsMinimalSelect)
at System.Windows.Controls.DataGrid.HandleSelectionForCellInput(DataGridCell cell, Boolean startDragging, Boolean allowsExtendSelect, Boolean allowsMinimalSelect)
at System.Windows.Controls.DataGridCell.OnAnyMouseLeftButtonDown(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseDownThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Window.ShowHelper(Object booleanBox)
at System.Windows.Window.ShowDialog()
at Eto.Wpf.Forms.DialogHandler.ShowModal() in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\DialogHandler.cs:line 67
at Honeybee.UI.ConstructionManagerViewModel.ShowConstructionDialog(IConstruction c, Boolean isIDEditable)
at Honeybee.UI.ConstructionManagerViewModel.<get_DuplicateCommand>b__29_0()
at Eto.Forms.RelayCommand`1.Execute(Object parameter)
at Eto.Forms.Button.OnClick(EventArgs e)
at Eto.Forms.Button.Callback.OnClick(Button widget, EventArgs e)
at Eto.Wpf.Forms.Controls.ButtonHandler`3.<Initialize>b__14_0(Object sender, RoutedEventArgs e) in D:\BuildAgent\work\commercial\src4\DotNetSDK\Eto\src\Eto.Wpf\Forms\Controls\ButtonHandler.cs:line 69
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at Eto.Forms.Dialog`1.ShowModal(Control owner)
at Pollination.RH.RhinoCommands.PO_ConstructionManager.ResourceManager(RhinoDoc doc)
at Pollination.RH.RhinoCommands.PO_ConstructionManager.RunCommand(RhinoDoc doc, RunMode mode)
