Hi, I’m trying to export a Revit model as HBJSON file. Only some part of the model gets converted while some things like curtain walls goes missing. I would be happy to share the file privately, if someone could check what is the issue.
Thanks.
Thanks.
Hi @samyukthaige,
How did you prepare the model? Did you select those curtain walls as glazing during the export process?
If that didn’t solve the problem, feel free to send it to me privately in a message.
Hi @mostapha
I did select all the glazing while exporting the model and it still didn’t export everything. I will share the model with you privately. Thank you for helping out with this issue.
