Daylight Autonomy Result different from IES Radiance
Hi All,
I have ran a daylight autonomy simulation with Pollination/Honey bee for the first time. However, I found the result is much different from the IES Radiance output, which I can’t tell which are more valid.
I have attached my honey bee model, as well as the DA simulation receipt. I only include sensor grid for 1 room for easy comparision.
The simulation is tested for the Green Star Building V1 protocol, which requires more than 160lux of daylight for more than 80% of the nominated time (7:00-19:00 for this case). The reflectance value are set to default as Wall 0.7/Ceiling 0.8/Floor 0.3, and all external window have VLT of 0.64.
My GH results indicate only 20% of the floor area has achieved this criteria, while IES Radiance gives a generouse result of 50%. The geometry should be exactly the same, as I output the Pollination model to IES in GEM.
Are there anything else that can affect the result by that much? Is my model setup correct?
DA Q&A.gh (82.0 KB)
PLAC program pool test.hbjson (3.9 MB)
I believe we have already helped other users with a similar comparison.
Hi @ivylili,
Which Radiance parameters did you use in IES?
In your file you left the Radiance parameters to the default parameters. You can use the HB Radiance Parameter component to create a set of parameters for different detail levels (0, 1, 2), and add them to the recipe. The recipe type must be set to 2 for annual daylight. You can also type your own parameters in a panel if you have some specific parameters.
Hi @ivylili ,
From past experience, I know that you can check and match your Radiance parameters between Pollination and IES. They might be using different default numbers for multiple parameters. We did a comparative study for DF, UDI and sDA with IES, Pollination and LB-HB Legacy. In a nutshell, the results were pretty much close to one another after making sure that we did enter the identical inputs with identical simulation settings.
Levent
