Daylight LEED option two - ERROR CreateVisMetadata
Guys, I’m trying to run the daylight option 2 recipe from the Rhino plugin, but the following error appears. “CreateVisMetadata”
What could be causing this?
Hi @anon77455912,
Which version of the plugin are you using?
The visualization feature was added to the recipe a few months ago at Isabella’s request. This issue should be resolved if you install the latest version of the plugin.
