I have a question regarding the possibility of running a daylight simulation directly from an architectural model using Pollination Rhino plugin without converting them into honeybee zones and then running it!
Hi @asisnath,
Similar to Ladybug Tools you can prepare the model with a face-based approach. All you need to do is to convert the faces to orphaned opaque surfaces, apertures, or shades.
It is valid to have a model that only consists of orphaned faces.
Wow! I didnt thought that way. Thanks @mostapha for this workflow. ![]()
