Encountering an error when loading a room preview?
When loading a model/room preview after step 4 in creating rooms tab, the spaces are loaded but I get a possible error in my preview shown below:
I try to create a snapshot and load it into the editor, but the editor also labels the snapshot file as invalid. Is there a way to access the error logs to get more information on the error?
Hi @srojas92, welcome to the forum! :waving_hand:
This is a similar error as this one:
https://discourse.pollination.cloud/t/invalid-building-roofspecification-must-have-at-least-one-face3d/4344
This is a bug that is happening because the model has no roof elements. We are working on a fix. Meanwhile, you should go ahead and create the snapshot. I shared a manual way with @mmeador for fixing this issue after exporting the snapshot.
Thank you @mostapha it is a pleasure working with your tools.
@mmeador reached out to me with the solution steps. I will reply back here if i have any trouble.
Hi @srojas92, thank you for the kind words and thank you for reporting the bug. We just released version 2.143.3 with a fix for this particular issue. Give it a try and let us know if the issue hasn’t been resolved.
Hi there, I am also experiencing difficulty viewing geometry and getting an error in the attached.
Hi @rwdhope,
This is a big that was introduced recently. It happens if you save a Revit file with Pollination information and open it again.
We will push a fix soon. Meanwhile, if you use the original Revit file and before saving any of the Pollination information it should work.
I’m copying @ksobon here so he’s aware of the issue.
Okay, thank you and yes it did work. :slight_smile:
@rwdhope, we released a new version today that fixes this issue (v2.220.4).
Once you download the new version, and if you have an older file with this issue, you can use the Enable/Disable Pollination button to clear the Pollination data.
