Energy recipes not working
Hi Mustapha,
I’ve tried to run various energy recipes available in Pollination for Rhino and all of them have failed. I’ve set up the model, construction, programmes, etc, following the pollination tutorials (most are a bit out of date but hopefully not so much that they are still relevant), but the sims just fail. Can you take a look and advise why Pollination keeps failing to run energy simulations?
Also, do all queries have to be public, or is there an option to message the pollination team directly to avoid company and project details being open to the public?
Many thanks in advance.
I’m trying to run an energy sim but it failed with this error message - can you confirm what it means and what needs to be done to get the energy use recipe to work:
Program Version,EnergyPlus, Version 23.2.0-7636e6b3e9, YMD=2024.12.15 15:39, ************* Beginning Zone Sizing Calculations  Weather file location will be used rather than entered (IDF) Location object. ** ~~~ ** ..Location object=SITE 1 ** ~~~ ** ..Weather File Location=London.Wea.Ctr-St.James.Park ENG GBR SRC-TMYx WMO#=037700 ** ~~~ ** ..due to location differences, Latitude difference=[51.50] degrees, Longitude difference=[0.13] degrees. ** ~~~ ** ..Time Zone difference=[0.0] hour(s), Elevation difference=[500.00] percent, [5.00] meters.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="HOSPITAL BLDG_SWH_EXTD_SCH_SAT", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="HOSPITAL BLDG_SWH_EXTD_SCH_SMRDSN", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="HOSPITAL BLDG_SWH_EXTD_SCH_WKDY", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="HOSPITAL BLDG_SWH_EXTD_SCH_WNTRDSN", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="SCHEDULE DAY 28", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="SCHEDULE DAY 29", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Year="0.05 HOT WATER LATENT FRACTION", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Year="0.2 HOT WATER SENSIBLE FRACTION", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated.
** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input. ** ~~~ ** Found first in surface=ROOM_5D36D9A6..FACE_F53E17CC ** ~~~ ** Defaults, constant throughout the year of (18.0) will be used.
** Warning ** CheckUsedConstructions: There are 12 nominally unused constructions in input. ** ~~~ ** For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
** Warning ** DetermineShadowingCombinations: There are 37 surfaces which are receiving surfaces and are non-convex. ** ~~~ ** ...Shadowing values may be inaccurate. Check .shd report file for more surface shading details ** ~~~ ** ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual warnings for each surface. ** Severe ** DetermineShadowingCombinations: There are 31 surfaces which are casting surfaces and are non-convex. ** ~~~ ** ...Shadowing values may be inaccurate. Check .shd report file for more surface shading details ** ~~~ ** ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual severes for each surface.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_04A2C146 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_08FBAFBD may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_0BD740C1 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_0ED66315 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_10D366F1 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_14661FDE may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_176C2823 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_1C62518B may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_1E89FD4F may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_2A5B1FD9 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_2AB823DA may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_2C63237C may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_2D3B80DB may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_5926A5F6 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_594EC04B may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_6301B9D4 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_6DA5624E may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_9B672CDC may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_A42C04B1 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_A94D12C9 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_AA8AA09E may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_AA9E733D may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_ACF19E08 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_AE9B0068 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_AF4C415A may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_B49F4108 may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_BA37735E may be inaccurate ** ~~~ ** because it has one or more vertices below ground level.
** Warning ** Calculation of reflected solar onto surface=ROOM_5D36D9A6..FACE_BAC2E9B5 may be inaccurate
So far all of my energy models have failed using pollination plug in for rhino. This is on multiple projects using different plug in recipes.
The err file is difficult to decipher, so I’m wondering if the UI could be developed to inform users why Pollination is failing?
So far the energy use and daylight recipes in pollination for rhino are causing no end of problems and it’s very obvious Pollination is still very much in beta stage and not ready to be used professionally, but it’d be helpful if there was a clearer diagnostic explaining what’s causing the issues in Pollination. Is this possible?
Hi @robm,
I merged all of your energy simulation-related questions here. The short answer is that you need to read the error messages that you copied above.
As I have mentioned before, for us to be able to help you, we need you to take the time to explain the issue better. I understand your complaints but they don’t help me to be able to help you. They just make your posts longer without adding much value.
Here is a short list that can help you:
  1. Tell us a bit about the model. If you have assigned any HVAC for instance, or edited the program types. If you have a guess about why it might be failing.
  2. Tell us if the model is valid. Have you run the validation command?
  3. Share the full error message with us. You can upload the error file.
Now to answer your specific questions:
No. You can send us private messages. It is a bit surprising that you ask this because we already have several private messages going on. You can use private messages to share your model, more details, etc.
The message is truncated. If you can share the full message we might be able to tell what needs to get fixed.
I’ll post a longer answer about this last point under your other post.
https://discourse.pollination.solutions/t/pollination-not-living-up-to-expectations-time-to-go-back-to-a-workable-set-up/4596
Hi Mustapha,
Thanks for your response, although I’m not quite following on this one, can you elaborate why certain people aren’t suitable for Pollination?
I think it could be a game changer and the creation of the HB rooms in the plug-in is fantastic on it’s own without using the recipes. However, I’ve experienced issues for the results for the daylight sim and energy recipes in the plug for rhino. I’ll revert back to each issue thread until the issues are fixed and really appreciate your support on this.
Ultimately, I’d like to be able to see that pollination works so I can promote role outs and deployment on many projects. So I’m very keen to persevere but it’s very challenging when fundamental issues arise which is difficult to trace back to a resolution in the online tutorials. I think I’ll need to be patient and create simpler test models. If the results keep failing it’d good to know why though.
Rather than copy the text over, is there any chance you can look at the results in some of the projects I’ve set up?
I can DM you with details.
Hi @robm, Sorry that I missed this one. Based on the email this issue has been resolved but you should always feel free to send me the information for the failing energy simulation in a private message and I will be happy to help you. Cheers.
