Energy Sim Fails when trying to run AFN on model exported from pollination
I exported a model from Revit using Pollination, however when I try to run a simulation with AFN I receive the following error:
  1. ** Severe ** Too many iterations (SOLVZP) in Airflow Network simulation
I tried to test it with another model exported with Pollination, however I am met with the same error.
Sharing the script for the same. Will appreciate any help with the issue, Thanks!
afn_failur.gh (66.0 KB)
Hi @pushkarnachan,
Thank you for posting the question. The error is most likely related to how you have set up the AFN and doesn’t have anything to do with how the geometry is exported from the Revit plugin. Unless the issue is rooted to something related to how the Revit plugin exports the model, this question should be posted to the Ladybug Tools forum.
