Hi team,
I am trying to copy of a few rooms and Rhino is giving this error:
Not sure, how can this be solved. To note the apertures of these zones have been copied from other rooms.
Hi @ishitasingh,
Thank you for reporting this. Can you help us create a minimal example to recreate the issue? I was not able to recreate the error. Do I need to do anything differently here?
I’m also adding @mingbo here to keep him in the loop.
Hi Mostapha,
Apologies, for the late response. I believe I had multiple zones and I was copying apertures from one zone to others by using the PO_DupAperturesDoors. Though, this error has not since popped up again. A colleague has faced a similar issue, hopefully she could clarify it further @lavanyanayak
Hi team,
yes, I faced a similar problem. The copy within the zone didnt work.
I am sharing the model for your reference via message.
Just to update this thread, the main issue here was that the geometries were locked.
