Hello, I’m trying to use the Grasshopper plugin on Rhino 7. Everything works fine, but when I try to install Pollination, I encounter this error while Grasshopper is loading, approximately at 94%. Does anyone know what could be the issue or how to solve it? I’m attaching a screenshot.
Hi @hbd, welcome to the forum!
@mingbo will correct me but from what I can see the issue is happening because you haven’t updated Rhino for some time. Try to update Rhino to a newer service release, and see if that fixes the problem.
Ok thanks mostapha I´ll try doing that!
