Yes exactly, exporting multiple options of the model (even parametrically) into IES would be very handy!
I tried to bake my Honeybee model with the Pollination Model component and I have this error
Hi @lorepatti,
Sorry for the issue! Can you share your model for debugging? If you share it via a message please also include @antonellodinunzio so he can help you with debugging the process.
As a workaround, you can save the model as an ‘HBJSON’ file using the Honeybee Dump component and then open that from inside Rhino directly.
