For some reason, I am able to modify Room Properties when I edit one room at a time. If I select two or more rooms and try to modify, the error above is received.
Thanks, @justinshultz! This is a bug and an annoying one. I can recreate it on my end with other models too.
@mingbo, I’m not sure if that’s the case, but it is most likely because now that you added the schema validation to the UI it tries to validate the identifier value, and "<varies>" is not a valid identifier.
Sorry, Justin for the inconvenience! Editing rooms one by one is not something that you should be doing! We should be able to fix this quickly once @mingbo gets a chance to review the issue.
Hi @mostapha and @mingbo is there an ETA on this fix or a workaround available? I am unable to edit multiple Rooms at once in the current Rhino Plug-In. I am working on a larger model now and need a better way to apply building wide updates to Program Type, Construction Set, HVAC etc.
@mingbo you are superhuman with your bug fixing speed. Thank you for getting this worked out. One less thing to stress about while working on my deadline.
