I am very new to Pollination, and while following the tutorial for exporting your first Revit Model on the import window step, i get the following error message:
Traceback (most recent call last): File "/lib/python313.zip/\_pyodide/\_base.py", line 597, in eval_code_async await CodeRunner( ...<9 lines>... .run_async(globals, locals) File "/lib/python313.zip/\_pyodide/\_base.py", line 411, in run_async coroutine = eval(self.code, globals, locals) File "<exec>", line 53, in <module> File "/home/pyodide/dragonfly/room2d.py", line 1563, in assign_sub_faces self.window_parameters = new_win_pars ^^^^^^^^^^^^^^^^ File "/home/pyodide/dragonfly/room2d.py", line 587, in window_parameters assert isinstance(bc, (Outdoors, Surface)), \\ \~\~\~\~\~\~\~\~\~\~^^^^^^^^^^^^^^^^^^^^^^^^^ AssertionError: Ground cannot be assigned to a wall with windows.
The Model Editor still says that the windows loaded successfully, however, they dont appear on the preview screen.
This is a screenshot of my preview window and where my progress stands with the Model Editor.
P.S. I did try to restart both Revit and the Model Editor, to no effect.
