Hello,
I am using Rhino 7.13 and have downloaded the latest version of pollination for grasshopper. I have tried downloading it multiple times but nothing seems to change the error. should I try with higher version of Rhino?
this is a very simple script for the reference.
the moment I turn the toggle to true the error shows.
Regards
Hi @sakshi,
The error is happening because of some recent changes to honeybee-doe2. If I have to guess, this is probably happening because your model has no rooms, and the recent changes in honeybee-doe2 expects the model to at least have one room.
@chriswmackey should be able to help.
Thanks for finding and reporting this bug, @sakshi . I just pushed a fix for it to our code base here:
… and I verified that it addresses your case.
I plan to trigger a new release of our installer within the next couple of hours and I’ll post here once I do so. @mostapha can let you know once we have an updated installer that we can send to you.
The workaround until we get you the updated installer is to add a dummy Room to the model or a ground Room with the HB Ground component.
okay Thankyou soo much for your help.
