Export to eQuest is taking a very long time
Hi @mostapha, thank you for fixing the error. I am able to update the multipliers now. when I try to export the model to inp, it appears to be taking a long time to load and is not exporting, but I am also not receiving any error messages on the log, I am not sure if I am doing it correctly? My process is after updating the multipliers for each level, I am selecting all the snapshots, solving adjacencies, and then clicking on the export to inp button:
The reason for this case was that the Pollination model was invalid and had many intersecting rooms. After fixing the issues with the model, the model was exported successfully.
We also learned that eQuest has a limitation of 120 for the maximum number of vertices. Accordingly, we had to break down the long hallways into smaller spaces (using the split command) to satisfy this requirement. We will add an additional validation item for this case soon.
